Blondozavr's avatar
Blondozavr
Netgear Night Hawk Xr1000 OFDMA lag in game
Hi.
I have a problem.
When I turn on OFDMA my ping in games starts to increase. I play on Playstation 5 connected via 5ghz wifi.
Geo-Filter - off
QOS - off
Internet Connection - 935/935
Channel 44.
Router version XR1000 1.0.0.74_1.0.63
  • FURRYe38's avatar
    Leave it off?
    Ethernet connect the console to the router instead?
    • Blondozavr's avatar
      Blondozavr
      Hi!
      Thanks for the quick response.
      Now the console can't even connect to the network with WIFI 😞
  • That may or may not be a cause, could be incidental but you've disabled the two features that would help you keep your ping low so I'd suggest using them and see if you get the same issue.
      Blondozavr
      Hi.
      Just turned it on:
      - Geofilter
      - QOS
      The console does not connect to the network.
      As soon as I turn OFDMA off everything works fine.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Are you adjusting the option while the console/game is on? If so reboot the console then check.
