- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear XR500 Dos Attack
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Day Everyone,
I recently got a new gateway from my isp. Plugged everything in and set it up in bridge mode. Noticed slow speeds so I opend up the router ui and checked logs page. All I am seeing inside the logs page is dos attack. I never had this issue before and have tried everything. Factory reset, software downgrade, a different gateway, static and dynamic ip. Still doing all that did not change a thing. When I plug my computer directly into the gateway everything works fine.
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:07:38
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:05:38
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:03:38
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:02:24
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:02:19
[DoS Attack: ACK Scan] from source: 131.188.12.211, port 80, Thursday, December 23, 2021 12:01:44
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:01:40
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:01:20
[DoS Attack: ACK Scan] from source: 131.188.12.211, port 80, Thursday, December 23, 2021 12:01:20
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:01:10
[DoS Attack: ACK Scan] from source: 131.188.12.211, port 80, Thursday, December 23, 2021 12:01:07
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:01:01
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 12:00:24
[DoS Attack: ACK Scan] from source: 131.188.12.211, port 80, Thursday, December 23, 2021 11:59:45
[DoS Attack: ACK Scan] from source: 198.166.40.25, port 8080, Thursday, December 23, 2021 11:59:45
[DoS Attack: ACK Scan] from source: 131.188.12.211, port 80, Thursday, December 23, 2021 11:59:33
[DoS Attack: ACK Scan] from source: 79.124.67.90, port 80, Thursday, December 23, 2021 11:59:27
[DoS Attack: ACK Scan] from source: 149.201.240.100, port 80, Thursday, December 23, 2021 11:59:27
[DoS Attack: ACK Scan] from source: 131.188.12.211, port 80, Thursday, December 23, 2021 11:59:27
[DoS Attack: ACK Scan] from source: 91.210.88.42, port 80, Thursday, December 23, 2021 11:59:27
[DoS Attack: ACK Scan] from source: 131.188.12.211, port 80, Thursday, December 23, 2021 11:59:25
[DoS Attack: ACK Scan] from source: 192.38.78.162, port 80, Thursday, December 23, 2021 11:59:23
[DoS Attack: ACK Scan] from source: 193.50.6.155, port 80, Thursday, December 23, 2021 11:59:23
[DoS Attack: ACK Scan] from source: 157.131.224.201, port 80, Thursday, December 23, 2021 11:59:17
[DoS Attack: ACK Scan] from source: 89.102.0.150, port 80, Thursday, December 23, 2021 11:59:17
[DoS Attack: ACK Scan] from source: 128.153.145.19, port 80, Thursday, December 23, 2021 11:59:11
[DoS Attack: ACK Scan] from source: 198.60.22.13, port 80, Thursday, December 23, 2021 11:59:11
[DoS Attack: ACK Scan] from source: 140.247.173.13, port 80, Thursday, December 23, 2021 11:59:10
[DoS Attack: ACK Scan] from source: 157.131.224.201, port 80, Thursday, December 23, 2021 11:59:09
[DoS Attack: ACK Scan] from source: 213.174.147.249, port 80, Thursday, December 23, 2021 11:59:09
[DoS Attack: ACK Scan] from source: 208.81.1.244, port 80, Thursday, December 23, 2021 11:59:06
[DoS Attack: ACK Scan] from source: 65.175.128.102, port 80, Thursday, December 23, 2021 11:59:04
[DoS Attack: ACK Scan] from source: 140.247.173.13, port 80, Thursday, December 23, 2021 11:59:04
[DoS Attack: ACK Scan] from source: 208.81.1.244, port 80, Thursday, December 23, 2021 11:59:04
[DoS Attack: ACK Scan] from source: 208.81.1.244, port 80, Thursday, December 23, 2021 11:59:02
[DoS Attack: ACK Scan] from source: 157.131.224.201, port 80, Thursday, December 23, 2021 11:59:01
[DoS Attack: ACK Scan] from source: 147.75.69.165, port 80, Thursday, December 23, 2021 11:59:01
[DoS Attack: ACK Scan] from source: 204.16.246.250, port 80, Thursday, December 23, 2021 11:59:00
[DoS Attack: ACK Scan] from source: 157.131.224.201, port 80, Thursday, December 23, 2021 11:59:00
[DoS Attack: ACK Scan] from source: 198.166.40.25, port 8080, Thursday, December 23, 2021 11:59:00
[DoS Attack: ACK Scan] from source: 208.81.1.244, port 80, Thursday, December 23, 2021 11:59:00
[DoS Attack: ACK Scan] from source: 198.60.22.13, port 80, Thursday, December 23, 2021 11:58:58
[DoS Attack: ACK Scan] from source: 128.211.151.252, port 80, Thursday, December 23, 2021 11:58:56
[DoS Attack: ACK Scan] from source: 216.17.3.16, port 80, Thursday, December 23, 2021 11:58:52
[DoS Attack: ACK Scan] from source: 38.229.66.100, port 80, Thursday, December 23, 2021 11:58:51
[DoS Attack: ACK Scan] from source: 69.65.16.171, port 80, Thursday, December 23, 2021 11:58:50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear XR500 Dos Attack
The speed issue will likely be because you haven't yet set your expected speeds in bandwidth settings or you've lowered Congestion Control on the QoS page
