Wirus's avatar
Wirus
Tutor
Oct 04, 2022
Netgear xr1000 Downlad speed slow
Hi, having an issue with my Netgear xr1000. Recently i,ve updated my internet plan to speed of 330 mb/s download and 42 mb/s upload. Now when i use the benchmark from DumaOS it shows that i have speeds of 42 mb/s download and 9 mb/s upload which is correct. Now the issue is that my download speed do not exceed 4 mb/s when downloading a game for example. I've tried different settings on DumaOS but it's the same. Whwn i connect to my  internet provider modem i get the full speed but trough xr1000 i don't.
Firmware vers is 1.0.0.64_1.0.49. I am using the 2.4 G for most of my in house devices and 5G for my PC and Phones. My pc is connected  trough Wireless connection and cannot use LAN because atm i don't have a LAN cable that long. The router and PC are in the same room. Thank you
  • You mention that the speeds you get in Connection Benchmark are 42Mbits which is correct, but that doesn't sound correct, you say you've upgraded to 330Mbits? If there's a reason you'd expect the XR to be getting much lower speeds than this can you let us know?
    Also, what game client/service are you downloading through? For example, Steam, Battle.net, Origin, etc?
    • Wirus's avatar
      Wirus
      Tutor
      Well yes. I’ve upgraded to 330 mb/s but the this numbers are give by the internet provider and to get the real speeds those numbers needs to be divided by 8. I am using Battle.net and Ubisoft clients.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Can you provide a screenshot of your QoS page please? Are all devices connected to the XR or are some still connected to the hub? Have you put the XR in the DMZ of the hub?
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    A wired speed test should be performed with the PC to check wired speed results.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
