Stevecook's avatar
Stevecook
Apprentice
Oct 23, 2018
Netgear xr500 doesn't detect internet to install
I'm trying to install the xr500 but when I go to router login and hit install it say I'm not connected to internet but if I hook my laptop up directly to mode which is netgear cm1000 the laptop. Connects to internet. Please help or just going return this router and try something else.
  • FURRYe38's avatar
    Power OFF both CM and XR. Power ON the CM modem first and let it sync. Power ON the XR router and walk thru the setup wizard with a wired PC connected to the XR router.
    Be sure to use a good quality LAN cable between the modem and router.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      It may be because they both default to the same IP address, if thats not the case you should definitely be able to access it via the default LAN IP which is 192.168.1.1 to complete setup
      • FURRYe38's avatar
        The CM doesn't have a router thus it won't have a 192.168.1.1 address. The Address should be 192.168.100.1. Mine is.
        Try swapping out LAN cabling between the CM and XR.
