× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk AC2600 R7450 router. COD4, how do i use two xbox's and them not interfere with one another
SnortNplay
Follower
So i Have two xbox ones hooked up directly to my router Via ethernet CAT 6 cables. I have one xbox as DMZ server and other one port Forwarded. If i am playing COD4 blackout and my GF turns on her xbox i get connection interrupted. Also i had my QOS for my xbox set on highest and i just keep hers at high and hers seems to run more smooth than mine and the QOS doesnt really seem to do much. Ill get 4,200 kbps bandwith and same with her. i feel like our bandwith should be higher and feel like the xbox's interfere with one another.. im stumped here. i have 30 mbps upload and  450 mbps download.
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 2
Guru
Re: Nighthawk AC2600 R7450 router. COD4, how do i use two xbox's and them not interfere with one ano
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Set NAT Filter to OPEN.
Remove DMZ and Port Forward Configurations. uPnP is only needed.
Good Luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1053 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
