× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Opening Port for Arlo
colieville
We've recently purchased an Arlo security system.  Unfortunately, it appears as though the Arlo system won't stay connected to the router.  After mulitple conversations with Arlo and Netgear, I've discovered that i need to open the ports.  I believe i have the settings, but when i try to add the custom service under port forwarding, I get a message that won't allow me to make changes.   (The specified ports are being used by other configurations.) I've been on hold for help with Netgear almost 2 hours now...not sure if anyone knows I'm on the line.  Can anyone help? Thank you
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 8
Netduma-Fraser
NetDuma Partner
Re: Opening Port for Arlo
I'd first try disabling Smart Connect for WiFi and manually connecting it to 2.4 or 5GHz as that might be the culprit. UPnP should open the ports that are needed so not sure that's the cause, what are the ports that have been added and what do you still need to add?
Message 2 of 8
colieville
It is connected via ethernet cable. I'm hoping it is a defective Arlo hub and a replacement will correct the issue.
Message 3 of 8
colieville
We were able to add the ports and that did not correct the issue.
Message 4 of 8
Netduma-Fraser
NetDuma Partner
Could you try disabling QoS completely from the Anti-Bufferbloat options please and see if that allows it to work correctly?
Message 5 of 8
colieville
Anti-Bufferbloat was marked “never”. Arlo was dropping from the router. So, I switched it to “When High Priority Traffic detected”. I also allocated more bandwidth to the Arlo hub. Unfortunately, it is still dropping...
Message 6 of 8
colieville
It is not a defective Arlo hub. Got the replacement today and same issues...
Message 7 of 8
Netduma_Alex
NetDuma Partner
Try disabling QoS completely by openining the Anti-Bufferbloat side menu and choosing Disable QoS.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1949 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
