Netduma-Fraser's avatar
Netduma-Fraser
NetDuma Partner
Dec 17, 2019
Please read if you're experiencing DumaOS not loading/login interface issues
We have received multiple reports about these issues. I have reported this to our team as this seems to be affecting a few people today, please follow these instructions provided as a workaround while we investigate. Please try a factory reset first before trying this workaround using the button at the back of the router and holding it down for 30 seconds then allowing 1-2 minutes for boot up before accessing:
1. Go to http://routerlogin.net/adv_index.htm
2. Administration -> Firmware Update
3. Download this firmware (two versions below .56*) http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip
4. Unpack the .zip file
5. Browse to Image file
6. Upload
7. Go back to Administration -> Firmware Update and disable Auto Upgrade until we can say this has been resolved.
If you receive any errors on the .32 firmware then you may need to clear the cache/cookies on your web browser, if that doesn't solve it then do a factory reset, that should ensure no legacy issues have carried over.
We are sorry for any inconvenience this may have caused and will investigate this issue ASAP.
*This version lacks some security updates but this is unlikely to affect you as well as some features (e.g. Ping Assist & Device Manager Table View) from the .56 firmware.
