× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ProSafe GS116 Switch Only Connects to Netgear XR1000 Router with Crossover Cable
xheliosx
Initiate
It appear thay my newly aquired Netgear XR1000 router does not have MDI/MDI-X capability. The setup is stand-alone Cable Modem->XR1000->ProSafe GS116 Switch->PC. This same configuration worked perfectly using my old router (Apple Airport). However,with the XR1000, the switch only works if I use a crossover cable. Also, the crossover cable will not work if I use it to connect the XR1000 directly to a PC. This same crossover cable did work when connecting the Airport to a PC. So, it seems like the XR1000 does not support MDI/MDI-X? Can someone confirm that? Shouldn't the GS116 also have MDI/MDI-X and work without a crossover even if the XR1000 doesn't have MDI/MDI-X?
Regards
Message 1 of 4
antinode
Guru
Re: ProSafe GS116 Switch Only Connects to Netgear XR1000 Router with Crossover Cable
> [...] So, it seems like the XR1000 does not support MDI/MDI-X? [...]
   I don't have the hardware, so I can't confirm or refute, but someone
else recently climbed onto an unrelated thread with a similar complaint
about a different device:
      https://community.netgear.com/t5/x/x/m-p/2094106
So far, no one has believed it, but I'm beginning to wonder.
> [...] Shouldn't the GS116 also have MDI/MDI-X and work without a
   In principle, everyone should negotiate an optimal connection, no
matter what.  I have not seen a case where a cross-over cable was needed
(or prohibited) in the past twenty years.  And I have some pretty
antique junk here.
Message 2 of 4
Netduma-Fraser
NetDuma Partner
I can't see any references to this in the spec or manual, may be best to make a ticket directly with Netgear: http://support.netgear.com/
Message 3 of 4
xheliosx
Initiate
OK, ticket created. I'll post the results when I get a response.
Message 4 of 4
Discussion stats
  • 3 replies
  • 908 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
