× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Purchased a XR700 Router few weeks ago, worked great, but now only 2 ports work
MissStephanie
Follower
As the title reads, i purchased this router few weeks ago off ebay.  It did work great at first.  All of the ports worked without any hicups.  I have a good amount of devices that are not wireless , and so being hardwired is very important for them to work..Woke up the other morning and only two ports are working.  Any suggestions ?  I cant just go return it , and i would hate to think that  I am just **bleep** out of luck.
Model: XR700|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: Purchased a XR700 Router few weeks ago, worked great, but now only 2 ports work
What I would suggest is upgrading to this firmware: https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix using the TFTP method: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP and then doing a factory reset. That will make it the freshest firmware install possible and if the ports not working is a software issue this will hopefully resolve it.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 680 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
