× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Router keep dropping LAN connection with XBOX series X
UTLEYM
For whatever reason, this router keeps dropping LAN connection. I have 1 gig internet. I have no idea what is going on.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 13
Netduma-Liam
NetDuma Partner
Re: Router keep dropping LAN connection with XBOX series X
Sorry to hear this!
It is just with the Series X? No other devices are losing connection? Do you have access to the interface when the drops occur?
Message 2 of 13
jonbusinessacct
This was plauging me for several months and I found it was Netgear's security software.  10x speed improvements once these fixes were enabled.
Advanced Setup
Disable QOS
Disable Port Scanning and DOS Protections
Respond to Ping on Internet Port
Disable IGMP Proxying
Disable SIP ALG
Message 3 of 13
UTLEYM
Re: Router keeps dropping LAN connection with XBOX series X
No my wife was having issues this morning as well. I just bought this thing. One thing I did notice is that the white blinking LED will turn amber?
Message 4 of 13
UTLEYM
This didn’t work. Thank you for the recommendation though!
Message 5 of 13
UTLEYM
Additionally when I open the interface I get a huge question mark in the middle and I can’t change settings.
Message 6 of 13
Netduma-Liam
NetDuma Partner
Do you get that question mark when you try to access the interface during a drop or is it all the time? What firmware version are you currently running?
Message 7 of 13
UTLEYM
Yeah, I reset the device when I got home and everything worked perfect. As soon as the drop occurred and I tried to get on and mess with the settings I get that massive question mark. Whatever the latest update was. I’ll have to check when I get home.
Message 8 of 13
Netduma-Fraser
NetDuma Partner
Do you have an Adblocker on the web browser? If so then please disable that and it should appear correctly. Otherwise clear your browser cache/cookies and try again.
Message 9 of 13
UTLEYM
Still doesn’t change the fact it drops lan connection.
Message 10 of 13
Netduma-Liam
NetDuma Partner
Sure, but has that resolved the issue with the interface displaying? Once we've resolved that it'll be easier to troubleshoot the disconnections. Did you find out what firmware you are running?
Message 11 of 13
Draama
im having this exact same problem it just drop connection sometimes about 15 times in an hour and stops each drop lasts about 10-30 seconds idk what it is anymore 😞
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 12 of 13
Netduma-Fraser
NetDuma Partner
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 4060 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
