CCoelho's avatar
CCoelho
Set up nat OPEN XR 1000 PS5
Hi,
I was wondering if there is a user guide or video on how to set up nat open with the xr1000 and ps5. I havent been able to figure this out or find an guide.
  • FURRYe38's avatar
    The best NAT type you can get for any Sony game console is Type 2. Type 1 is the console connected to a modem or ONT unit with out a router built in. Type 2 is modem/ONT unit connected to a external wifi router. OPEN NAT is not a Sony nomenclature. Type 1 and 2 and others are. Open NAT is a Microsoft and Xbox console nonmenclature.
    • CCoelho's avatar
      CCoelho
      Thank you. Yes nat 1 connection is what I want to achieve on ps5 with xr1000
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        As above, NAT Type 1 and NAT Type 2 are Open. NAT Type 1 is ONLY possible when connecting through a modem. NAT Type 2 is the same as one except when you're connected through a router.
        You have an Open NAT.
