× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Slow wifi
TornApart
Guide
Slow wifi
I normally run hard wired but my cat7 is messed up so I switched to WiFi for the time being. I have 300mbps but only getting 30 Down and 5 up wirelessly. Is this normal? I’d think closer to 100 WiFi maybe I’m giving wireless too much credit.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
Guru
Re: Slow wifi
If you're running over 2.4ghz its not a horrible speed because 2.4ghz is much much slower and sensitive to inference. You should be able to get more out of 5ghz though.
Message 2 of 3
TornApart
Guide
Re: Slow wifi
I thought at first I had 5G selected but on this ps4 I only get 2.4. Only the pro has that option. All good anyway. Once I replace my bad cable I’ll be back to hardwired.
Thanks for the input.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1089 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
