Zevas1993's avatar
Apr 28, 2022
Uncaught TypeError: $(...)[0].getApp is not a function
i just updated the firmware and now i get this code
  • GabeThaViking's avatar
    GabeThaViking
    Dec 06, 2022
    Nevermind Clearing cashed images and files the pasted hour fixed it
  • michaelkenward's avatar
    michaelkenward
    Updated the firmware on what Netgear device? And from what firmware version to what version?
    And where do you see the message buried in your subject?
    • Zevas1993's avatar
      Zevas1993
      Tutor
      What to do if message is displayed after update, please give a solution
      Zevas1993
      Tutor
      I believe I was on 5084 and I updated to the most recent on the xr1000. I've been having issues for over a year now and I thought updating would help, now DumaOS doesn't even load and after 5 minutes of a red screen with a spinning white circle that error message pops up.
        michaelkenward
        That's not a Netgear firmware number. Maybe it is a Duma thing.
        While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
        You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
        Nighthawk Pro Gaming Routers - NETGEAR Communities
        Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
        I will ask the Netgear moderator to move your message.
        That's why it always helps to provide as much detail as possible when seeking help.
  • Just updated and came across this aswell. i am using google chrome so all i did was clear cache and it work again.
  • update router which i shouldnt have based on how im getting this error code then i factory reset and im still getting this error code
      • Wayned20's avatar
        Wayned20
        I just redownloaded the firmware I was on before the update cause clearly the firmware update was the problem and no I didn't I don't really plan on update to that firmware and try 50 million thing for it to work when I was fine on the past firmware
