- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR 700
- Mark as New
- Bookmark
- Subscribe
- Permalink
XR 700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so, this would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
@Smallfoot wrote:
I've had my nighthawk pro gaming xr700 router for about 5 months and ever since I got it and replaced my X10 router I have had nothing but lag during gameplay lag is so bad it's unbearable. Been experiencing packet loss and latency while playing Apex legends call of duty or any other online game set my router up with optimal settings for Apex legends still lagging shut off qos cuz I have 1Gig speeds and should not have any lag if I use my Xfinity gateway I experienced no lag I need help or I'm just going to trash this router tried disabling qos upgraded to beta firmware still problems persist
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
Ok, making sure about your modem configuration.
Are you getting wired speed test near 900Mbps? When I had this router, it was not getting anything near 900Mbps on the WAN to LAN tests...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
Often the reason it takes a long time to find a match is because there aren't enough servers in your selected radius, so it has to wait until one has spaces. The problem is exacerbated by being in a party, because it has to find a server with even more spaces. Solo players usually end up taking priority.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR 700
