× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Orbi WiFi 7 RBE973
Reply
XR300 2.4 network dropping out
hotchili
Follower
Hey,
So for the last month or so I’ve been having a lot of problems with the 2.4 GHz wifi network. My 5 GHz is all working fine, but anything connected via 2.4 ie Nest Cam, Echo, Music Streamer are constantly disconnecting, or worse, losing their set up entirely (music streamer). I go back through set up, see it in the network for a couple of days, then it’s gone.
I’ve just run the network set up on the router again to see if it changed anything but no luck.
I’ve also tried a variety of different channels but that doesn’t make a difference either.
I turned off QoS settings, no different
Please help. No idea what else to do
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 2
Netduma-Fraser
NetDuma Partner
Re: XR300 2.4 network dropping out
Give those devices reserved IP addresses in LAN Settings and see if that helps. Do you see any entries in the log file when it happens?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 598 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
