Orbi WiFi 7 RBE973
Reply
XR500 Duma OS 3.0
Iamcity
Tutor
XR500 Duma OS 3.0
What happened to DUMA OS 3.0? I'm starting to think that I bought this router for no reason. I mean I can control what servers I connect to but i did expect to have lower pings. I watched the video on Duma OS 3.0 and I'm intrigued about to see how it works.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 5
Guru
Re: XR500 Duma OS 3.0
I've read its in the final testing process.
Message 2 of 5
Netduma-Fraser
NetDuma Partner
Initial batch of testers were selected late last week for the XR500 so more batches and betas for the other routers will kick off soon as well. Your settings may not be optimal so take a look at these optimal settings guides which should help: http://support.netduma.com/en/support/solutions/folders/16000090646
Message 3 of 5
MrPChulo
I am hoping with the new DUMA OS update will fix my issue. The QOS and GEO filter made my sons PC ping ridiculously high (100-200). the other issue I had was that even though i saved the changes on the QOS bandwidth it will go back to 0% and all the devices connected would barely get any bandwidth even though i have 1gig speeds. I had no choice but to turn my router into an access point so all my devices worked properly.
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender, XR500|Nighthawk Pro Gaming Router
Message 4 of 5
Netduma-Fraser
NetDuma Partner
@MrPChulo I've not seen you make a post regarding that issue so it is likely a settings issue that is easily resolvable. If you make a topic and explain a bit more about the issues you're having then we'd be happy to help.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2156 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi 770 Series
