- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 Intermittent LAN Drops
- Mark as New
- Bookmark
- Subscribe
- Permalink
Current firmware: 2.3.2.130 (factory reset after downgrading)
DHCP range: 192.168.1.100-200
Reserved addresses: 192.168.2-50
DNS: 1.1.1.1/8.8.8.8
All QOS features disabled
IPv6 disabled
UPnP disabled
Smart Connect disabled
ISP: Spectrum
Modem: Spectrum D3.1 eMTA
Both 2.4 and 5GHz networks remain online when ethernet devices drop connection. The router does not power cycle.
This has been an ongoing problem for the past 3 months when the router was on 2.3.2.134. My ISP has already been here and was unable to find any WAN issue. I've used every LAN port and different cables and the problem persists. What am I missing? This is a daily occurrence and has made my network completely unreliable. Each time the drop occurs I need to reboot the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 Intermittent LAN Drops
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
Be sure to no change the DNS or uPnP settings, leave them at default for now...
Might go over to NetDuma web site and ask about the beta they are testing for the XR500.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sure, thank you for your time. It's still an ongoing issue.
https://drive.google.com/file/d/1XOZZ_ub5Yf0t_TR345KedW9cCSjy9x4O/view?usp=sharing
- Mark as New
- Bookmark
- Subscribe
- Permalink
