Orbi WiFi 7 RBE973
Reply
XR500 No 1733 Mpbs Option On 5Hz Band
weeswolf
The 5GHz band on my XR500 is limited to only "Up to 347 Mbps".  There are no other speed options, only this one.  Should I not have a 1733 Mbps option?
My firmware is version 2.3.2.114.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 5
Accepted Solutions
Netduma-Liam
NetDuma Partner
Re: XR500 No 1733 Mpbs Option On 5Hz Band
Yeah, as Plemans mentions, I'd suggest factory resetting as the issue occured after the update.
Message 5 of 5
All Replies
Netduma-Liam
NetDuma Partner
Could you please try switching to channel 48 and check if you have that option?
If not, did you factory reset after installing the latest firmware? Did you upgrade recently?
Message 2 of 5
weeswolf
I switched to channel 48 and clicked apply, but still only 347 Mbps is available as an option.
I did do an update last evening, the firmware now reads 2.3.2.114 and I did not do a factory reset - is that necessary?
Message 3 of 5
Guru
Its worth trying a factory reset if the issue cropped up after a firmware update.
Message 4 of 5
Netduma-Liam
NetDuma Partner
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1708 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
