× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 OR XR700?
Gimli
Tutor
XR500 OR XR700?
Is there a lot of difference between the xr 500 and the xr 700? Is it worth the exchange of the Xr500 for the XR700?
Thank you
Message 1 of 3
Accepted Solutions
Guru
Re: XR500 OR XR700?
There is. Just depends on if you have the client side HW that supports higher connection rates (AD) on wireless to take advantage of it and really need SPF media port support.
You can compare modes with the data sheets:
https://www.netgear.com/images/datasheet/networking/wifirouter/XR700.pdf
https://www.netgear.com/images/datasheet/networking/wifirouter/XR500.pdf
Message 2 of 3
All Replies
Guru
Re: XR500 OR XR700?
Message 2 of 3
Netduma_Jack
NetDuma Partner
Re: XR500 OR XR700?
XR700 also has Plex server support.
But DumaOS is the same on both.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2829 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
