× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
XR500 Wireguard
JPW162
XR500 Wireguard
I can get the hybrid vpn working with openvpn however can't seem to get wireguard going, should it work?
I was planning to use surfshark as the vpn provider. - if the xr500 isn't working with wireguard/dumaos can I flash ddwrt?
Message 1 of 8
Netduma-Fraser
NetDuma Partner
Re: XR500 Wireguard
Which firmware version are you currently on? Do you actually see the Wireguard option under the Advanced Setup on HybridVPN?
If you were to flash another software you would not be able to get back to DumaOS and it would invalidate your warranty so it isn't advised.
Message 2 of 8
JPW162
Re: XR500 Wireguard
XR500 V2.3.2.134
[Interface]
Address = 10.14.0.2/16
PrivateKey = ---
DNS = 162.252.172.57, 149.154.159.92
[Peer]
PublicKey = ---
AllowedIPs = 0.0.0.0/0
Endpoint = 84.39.114.157:51820
am I missing something? - can't seem to find the wireguard option sorry!
Message 3 of 8
Netduma-Fraser
NetDuma Partner
Re: XR500 Wireguard
Ah okay, it's not implemented currently, you would see it at the top of the config box with a menu for VPN Type to switch between OpenVPN and Wireguard. You'll have to continue using OpenVPN for the moment.
Message 4 of 8
JPW162
Re: XR500 Wireguard
is there any beta/alpha firmware in which it is implemented? It sounds like you were expecting it to already be there!
Message 5 of 8
Netduma-Fraser
NetDuma Partner
Re: XR500 Wireguard
Perceptive! It's not currently available and it was something we were working on but it was causing some pretty major issues, if we can resolve them then it will be implemented. If not then it might be something we have to defer.
Message 6 of 8
JackeyPL
Re: XR500 Wireguard
Great, I bought this router because I had read dumaos supports wireguard and netgear developers stated in 2022 it's almost ready... we have almost 2025, any progress?
Message 7 of 8
Netduma-Fraser
NetDuma Partner
Re: XR500 Wireguard
I know you've posted on our forum and I'll respond there also but there were a lot of issues with integrating it so much so that we decided to postpone it. That was about a year ago and since then we've updated to DumaOS 4 which the XR range won't get unfortunately.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3283 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
