Kemtach2999's avatar
Kemtach2999
XR500 & EX2700 compatability issue
Hi all,
I consider myself quite tech savvy, but this is beyond me.
The backstory: I have recently moved house and I am currently trying to set up a small office in the spare room of the new property.
Issue 1 - limited wifi in said room - The router is connected in the living room downstairs, and the office is in the top room at the back of the house (Virgin router didn't reach and apparently the XR500 doesn't quite make it either. Solution Range Extender
Now in terms of accessing the Internet though the Extender I'm having no real issue (I'm connected using the extender right now) however DumaOS is showing this PC as offline ( I have completed the Netgear steps to assign one SSID to both the XR500 and N300 extender)
This is having the follow on issue of not being able to connect my printer (HP M553n) to the network - I have tried connecting the printer to the ethernet port of the N300 extender but I'm still not getting any joy.
My question:
Should the N300 be communicating with the XR500 (thus showing devices connected through it as online in DumaOS) If so, how do I get Duma to recognize those devices (currently this PC and the Printer)
Using IP Config to ping the address of the N300 returns a 0% loss rate, however pinging the address of the printer returns a 100% loss rate, implying that the printer isn't connected to the network
Any help provided would be most gratefully received
  • FURRYe38's avatar
    Does the printer show up if directly connected to the XR router?
    The EX is an older model extender. Possible some incompatibility with new XR Wifi and connections.
    Is Smart connect enabled on the XR router?
    • Kemtach2999's avatar
      Kemtach2999
      Hi,
      Thank you both for your replies.
      At the moment the printer is not showing up when directly connected to the router - despite the network port showing signs of activity. (steady green light, flashing amber light)
      I've checked DumaOS and yes, smart connect is enabled.
      With regard to the offline PC - somehow over night it has resolved itself and now shows under the correct address on DumaOS
      As for the printer it is under a static IP address which is different to the IP addresses asigned by the router - HP address is 192.168.1.132 - all current IP addresses are 10.0.0.x
      • schumaku's avatar
        schumaku
        So this is the only issue remaining when I get it right.
        First think about why the XR500 has changed to the 10.0.0.x/24 network - this does happen typically under double NAT situations where e.g. a provider router does NAT and use the 192.168.1.x/24 network. Some of these (but less and less) can be re-configured to modem or transparent modes. If this is not feasible, change the HP config to DHCP, make a reservation for its IP-MAC pair on the router, and then you might consider changing it to that very same fixed IP.
  • schumaku's avatar
    schumaku
    Now in terms of accessing the Internet though the Extender I'm having no real issue (I'm connected using the extender right now) however DumaOS is showing this PC as offline ( I have completed the Netgear steps to assign one SSID to both the XR500 and N300 extender).
    The "offline" PC does it show up under it's real MAC address where it was used to connect before, or the virtual MAC - as the older extenders are doing MAC translation - which is different from the effective MAC ... so I guess the DumaOS does make two devices out of it (just like any other router or the "classic" Nighthawks before).
    Either case, it's just L2 communication - if the PC can talk to the Internet it must be visible somehow and somewhere on the DumaOS network map, under a different MAC address (see the connected devices list on the EX2700) for the "Virtual MAC".
    Similar for the printer - there is a MAC address translation - we can assume it does show up in the EX2700 connected device list (with real MAC, with Virtual MAC, and even it's IP address) - please check this.
    When you say ping the printer IP - is this an IP address assigned by DHCP from the router, or was the printer configured to a static (fixed) IP address?
    If it's a static IP config, is the IP address/mask/gateway in the same subnet like the XR500 LAN subnet and the connected system from where you run the test?
