Orbi WiFi 7 RBE973
Reply
XR500 has devices offline that are not and is preventing functionality
mandms7
Tutor
I recently purchased an XR500 and upgraded it to the latest firmware (2.3.2.56). I have already factory reset it twice. I have several devices that in Device Manager are showing offline, including my only gaming system, which is hard wired into the router itself. If using Table View in Device Manager, the port shows as connected under Ports Table but under Devices Table, it shows as being offline with no IP address assigned. My PC has shown up this way for the last 5 days. Because of this, no QoS rules are being assigned to the traffic originating from my PC. I'm not sure what else is impacted as a result of this.
Given that the primary purpose of this router is to prioritize gaming, and my only gaming system is being incorrectly identified as offline, this router is doing nothing more than any other off the shelf router. Other people have complained about this same issue, and so far it seems that nothing is being done to address it.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 16
Netduma-Fraser
NetDuma Partner
Re: XR500 has devices offline that are not and is preventing functionality
This is an issue we're aware of and will be fixing, if you're willing to downgrade to .32 in the meantime while get fix it then it will work.
Message 2 of 16
mandms7
Tutor
Ok. It didn't seem like it was being addressed in other threads, so glad to hear it is being worked on.
Message 3 of 16
Allendc1
Guide
does this issue also apply to having a WAC540 AP connected to a XR500, and none of the AP clients showing on the XR500??
Message 4 of 16
Netduma_Alex
NetDuma Partner
No that's likely an unrelated issue to do with the fact that the individual MAC addresses aren't being forwarded to the XR500.
Message 5 of 16
Any update on when a fix will be available to address devices showing as offline when in fact they are not?
Message 6 of 16
Guru
NG doesn't post when new FW is forthcoming. So you'll have to keep an eye out on there download web page.
Downgrade FW if its that important to you to v32.
Message 7 of 16
Even though the devices are showing offline, are they still abiding by QoS and Geo-Location features?
Message 8 of 16
Netduma_Alex
NetDuma Partner
I'm pretty sure that any rules they would usually be effected by will still be active.
Message 9 of 16
aaronrdaniels
Any Updates on this I still have this issue at this date... I am fully updated.
Message 10 of 16
Netduma-Fraser
NetDuma Partner
We have implemented a solution to this in DumaOS 3.0 so when this is released you'll be able to delete devices easily.
Message 11 of 16
mandms7
Tutor
I resolved it by returning the router and getting something else.
Message 12 of 16
Retired_Member
Not applicable
Found this thread while troubleshooting/searching for info on my new and fairly expensive device.
Pretty dissapointed to see its a known issue for atleast a year.
Message 13 of 16
Netduma-Fraser
NetDuma Partner
I would highly recommend signing up to the 3.0 beta so you can get into it sooner http://www.netgearinnovation.com/dumaos-beta/index.html
Message 14 of 16
Retired_Member
Not applicable
Still no fix. Nice.
Message 15 of 16
Netduma-Fraser
NetDuma Partner
Did you do a factory reset after upgrading? If not I would suggest doing that because it is quite a jump in firmware.
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 7008 views
  • 4 kudos
  • 8 in conversation
Announcements
Orbi 770 Series
