Orbi WiFi 7 RBE973
Reply
XR500
Addiboss
Follower
XR500
I buy the router used and I can’t go into the settings because they change the default password and don’t no the answer to the security questions can NETGEAR factory reset my router
Message 1 of 2
Guru
Re: XR500
 You can factory reset. Push and hold reset for up to 15 seconds while its powered on.
That should reset it and then you can just follow the manual fo reinstall.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 566 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
