syycoe
Jul 19, 2020Aspirant
Xr500 DHCP lease change
Hello I am having problems with everything disconnecting every 15mins coinciding with lease times,everything reconnects eventually but it is impossible to game as getting kicked all the time and have reverted back to isp router,tried setting reserved up’s turning off DHCP but nothing works if I turn it off as TalkTalk connect via DHCP,if I revert to an old FW is there 1 which didn’t have this problem,have signed up to the beta in hope it is fixed but with 2 teenagers constantly complaining about disconnects it is causing a problem
Many thanks
Many thanks
- Netduma-FraserNetDuma PartnerIs this happening on wired devices as well? In Internet Setup switch to Static there and see if that helps. Also if you go to Settings > Monitoring > Connection Status what does DHCP lease say for obtained/expires?
