- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xr500 Dropping Connection Every day
- Mark as New
- Bookmark
- Subscribe
- Permalink
XR500 V2.3.2.134
For some reason my xr500 has become unreliable in the sense it is dropping connection every day. It has never done this and has just started. I have been on the most current firmware version for a year now. Nothing has changed. The internet will disconnect then reconnect in under 2 minutes. I have factory reset and the connection drops are still occurring. At this point I truly need to highlight the error as I work from home quite a bit. In the router logs a ton of the following is occurring:
[DoS Attack: SYN/ACK Scan] from source: 178.63.206.246, port 443, Tuesday, October 10, 2023 00:22:40
[DumaOS] DHCP new event., Tuesday, October 10, 2023 00:20:38
[DHCP IP: 192.168.1.3] to MAC address a8:23:fe:6c:a1:0c, Tuesday, October 10, 2023 00:20:38
[DoS Attack: SYN/ACK Scan] from source: 178.63.206.246, port 443, Tuesday, October 10, 2023 00:18:36
[DumaOS] applying qos for zone lan, Tuesday, October 10, 2023 00:17:27
[DumaOS] applying qos for zone wan, Tuesday, October 10, 2023 00:17:27
[DumaOS] config write 'com.netdumasoftware.qos.settings', Tuesday, October 10, 2023 00:17:26
[DoS Attack: SYN/ACK Scan] from source: 178.63.206.246, port 443, Tuesday, October 10, 2023 00:12:54
[admin login] from source 192.168.1.5, Tuesday, October 10, 2023 00:11:25
[DumaOS] DHCP new lease allocated., Tuesday, October 10, 2023 00:06:20
[DumaOS] DHCP new event., Tuesday, October 10, 2023 00:06:20
[DHCP IP: 192.168.1.5] to MAC address c8:7f:54:56:05:14, Tuesday, October 10, 2023 00:06:20
[DoS Attack: SYN/ACK Scan] from source: 46.63.116.120, port 443, Monday, October 09, 2023 23:21:41
[DoS Attack: TCP/UDP Chargen] from source: 89.248.163.131, port 45148, Monday, October 09, 2023 22:47:53
[DoS Attack: RST Scan] from source: 44.206.2.109, port 8443, Monday, October 09, 2023 22:41:51
[DoS Attack: RST Scan] from source: 44.206.2.109, port 8443, Monday, October 09, 2023 22:25:11
[DoS Attack: WinNuke Attack] from source: 219.122.229.46, port 58020, Monday, October 09, 2023 22:17:52
[DoS Attack: SYN/ACK Scan] from source: 154.31.18.26, port 80, Monday, October 09, 2023 21:30:25
[DumaOS] The selected theme does not exist: 'default', Monday, October 09, 2023 21:22:37
[DumaOS] Theme path does match manifest 'default', Monday, October 09, 2023 21:22:37
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Monday, October 09, 2023 21:22:37
[DoS Attack: SYN/ACK Scan] from source: 198.12.210.211, port 443, Monday, October 09, 2023 21:06:04
[DoS Attack: SYN/ACK Scan] from source: 51.79.239.33, port 19085, Monday, October 09, 2023 19:54:55
[DoS Attack: SYN/ACK Scan] from source: 51.79.239.33, port 19085, Monday, October 09, 2023 19:50:12
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Monday, October 09, 2023 19:48:22
[DumaOS] DHCP lease change., Monday, October 09, 2023 19:48:21
[DumaOS] DHCP new event., Monday, October 09, 2023 19:48:21
[DHCP IP: 192.168.1.2] to MAC address ea:0f:80:e6:d1:b4, Monday, October 09, 2023 19:48:21
[DoS Attack: SYN/ACK Scan] from source: 185.73.243.144, port 25565, Monday, October 09, 2023 19:17:20
[DumaOS] DHCP lease change., Monday, October 09, 2023 18:53:58
[DumaOS] DHCP new event., Monday, October 09, 2023 18:53:58
[DHCP IP: 192.168.1.6] to MAC address 38:64:07:3b:df:ab, Monday, October 09, 2023 18:53:58
[DoS Attack: RST Scan] from source: 147.182.238.12, port 22, Monday, October 09, 2023 18:36:04
[DoS Attack: RST Scan] from source: 52.223.202.162, port 80, Monday, October 09, 2023 18:28:04
[DumaOS] DHCP lease change., Monday, October 09, 2023 18:14:34
[DumaOS] DHCP new event., Monday, October 09, 2023 18:14:34
[DHCP IP: 192.168.1.6] to MAC address 38:64:07:3b:df:ab, Monday, October 09, 2023 18:14:34
[DoS Attack: ACK Scan] from source: 178.128.82.89, port 8768, Monday, October 09, 2023 17:42:15
[DoS Attack: TCP/UDP Echo] from source: 68.105.29.11, port 53, Monday, October 09, 2023 17:37:10
[DoS Attack: TCP/UDP Echo] from source: 68.105.28.12, port 53, Monday, October 09, 2023 17:37:10
[DoS Attack: TCP/UDP Echo] from source: 68.105.28.11, port 53, Monday, October 09, 2023 17:37:10
[DoS Attack: TCP/UDP Echo] from source: 68.105.29.11, port 53, Monday, October 09, 2023 17:37:07
[DoS Attack: TCP/UDP Echo] from source: 68.105.28.11, port 53, Monday, October 09, 2023 17:37:07
[DoS Attack: TCP/UDP Echo] from source: 68.105.28.12, port 53, Monday, October 09, 2023 17:37:07
[DoS Attack: TCP/UDP Echo] from source: 68.105.28.11, port 53, Monday, October 09, 2023 17:37:05
[DoS Attack: SYN/ACK Scan] from source: 199.231.233.147, port 30120, Monday, October 09, 2023 17:23:06
[DoS Attack: SYN/ACK Scan] from source: 199.231.233.147, port 30120, Monday, October 09, 2023 17:23:02
[DoS Attack: SYN/ACK Scan] from source: 199.231.233.147, port 30120, Monday, October 09, 2023 17:23:00
[DoS Attack: SYN/ACK Scan] from source: 199.231.233.147, port 30120, Monday, October 09, 2023 17:22:59
[DumaOS] Cloudsync DPI result 'nil','failed to sync', Monday, October 09, 2023 17:22:42
[DumaOS] Cloudsync DPI 'skipping mirror', Monday, October 09, 2023 17:22:42
[DumaOS] Cloudsync DPI 'HTTP sync failed', Monday, October 09, 2023 17:22:42
[DumaOS] HTTP download failed with code '404', Monday, October 09, 2023 17:22:42
[DumaOS] The selected theme does not exist: 'default', Monday, October 09, 2023 17:22:37
[DumaOS] Theme path does match manifest 'default', Monday, October 09, 2023 17:22:37
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Monday, October 09, 2023 17:22:37
[DoS Attack: ACK Scan] from source: 46.101.28.153, port 31988, Monday, October 09, 2023 17:16:30
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:42:46
[DumaOS] DHCP new event., Monday, October 09, 2023 16:42:46
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:42:46
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:42:39
[DumaOS] DHCP new event., Monday, October 09, 2023 16:42:39
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:42:39
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:42:31
[DumaOS] DHCP new event., Monday, October 09, 2023 16:42:31
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:42:31
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:42:28
[DumaOS] DHCP new event., Monday, October 09, 2023 16:42:28
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:42:28
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:42:02
[DumaOS] DHCP new event., Monday, October 09, 2023 16:42:02
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:42:02
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:41:49
[DumaOS] DHCP new event., Monday, October 09, 2023 16:41:49
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:41:49
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:41:23
[DumaOS] DHCP new event., Monday, October 09, 2023 16:41:23
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:41:23
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:40:58
[DumaOS] DHCP new event., Monday, October 09, 2023 16:40:58
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:40:58
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:40:46
[DumaOS] DHCP new event., Monday, October 09, 2023 16:40:46
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:40:46
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:40:35
[DumaOS] DHCP new event., Monday, October 09, 2023 16:40:35
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:40:35
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:40:23
[DumaOS] DHCP new event., Monday, October 09, 2023 16:40:23
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:40:23
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:39:56
[DumaOS] DHCP new event., Monday, October 09, 2023 16:39:56
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:39:56
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:39:30
[DumaOS] DHCP new event., Monday, October 09, 2023 16:39:30
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:39:30
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:39:18
[DumaOS] DHCP new event., Monday, October 09, 2023 16:39:18
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:39:18
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:38:53
[DumaOS] DHCP new event., Monday, October 09, 2023 16:38:53
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:38:53
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:38:26
[DumaOS] DHCP new event., Monday, October 09, 2023 16:38:26
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:38:26
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:38:23
[DumaOS] DHCP new event., Monday, October 09, 2023 16:38:23
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:38:23
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:38:18
[DumaOS] DHCP new event., Monday, October 09, 2023 16:38:18
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:38:18
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:38:13
[DumaOS] DHCP new event., Monday, October 09, 2023 16:38:13
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:38:13
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:38:08
[DumaOS] DHCP new event., Monday, October 09, 2023 16:38:08
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:38:08
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:38:00
[DumaOS] DHCP new event., Monday, October 09, 2023 16:38:00
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:38:00
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:37:57
[DumaOS] DHCP new event., Monday, October 09, 2023 16:37:57
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:37:57
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:37:51
[DumaOS] DHCP new event., Monday, October 09, 2023 16:37:51
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:37:51
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:37:46
[DumaOS] DHCP new event., Monday, October 09, 2023 16:37:46
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:37:46
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:37:33
[DumaOS] DHCP new event., Monday, October 09, 2023 16:37:33
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:37:33
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:37:21
[DumaOS] DHCP new event., Monday, October 09, 2023 16:37:21
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:37:21
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:36:55
[DumaOS] DHCP new event., Monday, October 09, 2023 16:36:55
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:36:55
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:36:42
[DumaOS] DHCP new event., Monday, October 09, 2023 16:36:42
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:36:42
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:36:16
[DumaOS] DHCP new event., Monday, October 09, 2023 16:36:16
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:36:16
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:35:43
[DumaOS] DHCP new event., Monday, October 09, 2023 16:35:43
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:35:43
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:35:39
[DumaOS] DHCP new event., Monday, October 09, 2023 16:35:39
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:35:39
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:35:34
[DumaOS] DHCP new event., Monday, October 09, 2023 16:35:34
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:35:34
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:35:25
[DumaOS] DHCP new event., Monday, October 09, 2023 16:35:25
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:35:25
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:35:21
[DumaOS] DHCP new event., Monday, October 09, 2023 16:35:21
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:35:21
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:35:17
[DumaOS] DHCP new event., Monday, October 09, 2023 16:35:17
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:35:17
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:35:12
[DumaOS] DHCP new event., Monday, October 09, 2023 16:35:12
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:35:12
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:35:04
[DumaOS] DHCP new event., Monday, October 09, 2023 16:35:04
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:35:04
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:35:00
[DumaOS] DHCP new event., Monday, October 09, 2023 16:35:00
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:35:00
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:55
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:55
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:55
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:54
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:54
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:54
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:48
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:48
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:48
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:39
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:39
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:39
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:35
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:35
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:35
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:34
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:34
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:34
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:32
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:32
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:31
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:22
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:22
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:22
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:17
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:17
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:17
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:34:12
[DumaOS] DHCP new event., Monday, October 09, 2023 16:34:12
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:34:12
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:33:45
[DumaOS] DHCP new event., Monday, October 09, 2023 16:33:45
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:33:45
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:33:33
[DumaOS] DHCP new event., Monday, October 09, 2023 16:33:33
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:33:33
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:33:11
[DumaOS] DHCP new event., Monday, October 09, 2023 16:33:11
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:33:11
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:33:08
[DumaOS] DHCP new event., Monday, October 09, 2023 16:33:08
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:33:08
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:32:41
[DumaOS] DHCP new event., Monday, October 09, 2023 16:32:41
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:32:41
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:32:28
[DumaOS] DHCP new event., Monday, October 09, 2023 16:32:28
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:32:28
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:32:14
[DumaOS] DHCP new event., Monday, October 09, 2023 16:32:14
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:32:14
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:32:01
[DumaOS] DHCP new event., Monday, October 09, 2023 16:32:01
[DHCP IP: 192.168.1.8] to MAC address 2c:33:58:81:5d:a8, Monday, October 09, 2023 16:32:01
[DumaOS] DHCP lease change., Monday, October 09, 2023 16:31:34
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500 Dropping Connection Every day
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
That many changes in DHCP Lease for one device is a problem. What is this device at 192.168.1.8?
I'd do a whois look up on those other WAN side IP addresses to see where they are coming from.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
