- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xr700 disconnects from xbox
- Mark as New
- Bookmark
- Subscribe
- Permalink
xr 700 discconecting ,I gettingDHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP lease change., Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP new event., Thursday, December 27, 2018 17:11:07 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP lease change., Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP new event., Thursday, December 27, 2018 17:11:07 [DumaOS] No wifi metadata for mac '2c:54:91:99:2a:10', Thursday, December 27, 2018 17:11:06 [DumaOS] No wifi metadata for mac '01:00:5e:00:00:16', Thursday, December 27, 2018 17:11:06 [DumaOS] No wifi metadata for mac '01:00:5e:00:00:fb', Thursday, December 27, 2018 17:11:06 [DumaOS] No wifi metadata for mac '01:00:5e:7f:ff:fa', Thursday, December 27, 2018 17:11:06 [DumaOS] Error parsing line in ARP table: 'fe80::f0e2:8d51:dbbf:b5f2 dev br0 lladdr 2c:54:91:99:2a:10 REACHABLE', Thursday, December 27, 2018 17:10:58 [DumaOS] Error parsing line in ARP table: 'fe80::1429:d42d:298a:94d4 dev br0 lladdr bc:e1:43:bf:15:3e REACHABLE', Thursday, December 27, 2018 17:10:58 [DumaOS] Error parsing line in ARP table: 'fe80::ce6e:a4ff:fefc:157a dev br0 lladdr cc:6e:a4:fc:15:7a REACHABLE', Thursday, December 27, 2018 17:10:58 [DumaOS] Error parsing line in ARP table: 'fe80::1659:c0ff:fe4d:f3d9 dev br0 FAILED'., Thursday, December 27, 2018 17:10:58 [DumaOS] No wifi metadata f a message in system log. any one no how to fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr700 disconnects from xbox
What FW is currently loaded?
How is the xbox connected to the router? wired or wireless? Wired is preferred.
Disable "Instant ON" feature on the xbox. This is known to cause problems between xbox and routers.
Set an IP address reservation for the xbox console ON the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP lease change., Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP new event., Thursday, December 27, 2018 17:11:07 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP lease change., Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP new event., Thursday, December 27, 2018 17:11:07 [DumaOS] No wifi metadata for mac '2c:54:91:99:2a:10', Thursday, December 27, 2018 17:11:06 [DumaOS] No wifi metadata for mac '01:00:5e:00:00:16', Thursday, December 27, 2018 17:11:06 [DumaOS] No wifi metadata for mac '01:00:5e:00:00:fb', Thursday, December 27, 2018 17:11:06 [DumaOS] No wifi metadata for mac '01:00:5e:7f:ff:fa', Thursday, December 27, 2018 17:11:06 [DumaOS] Error parsing line in ARP table: 'fe80::f0e2:8d51:dbbf:b5f2 dev br0 lladdr 2c:54:91:99:2a:10 REACHABLE', Thursday, December 27, 2018 17:10:58 [DumaOS] Error parsing line in ARP table: 'fe80::1429:d42d:298a:94d4 dev br0 lladdr bc:e1:43:bf:15:3e REACHABLE', Thursday, December 27, 2018 17:10:58 [DumaOS] Error parsing line in ARP table: 'fe80::ce6e:a4ff:fefc:157a dev br0 lladdr cc:6e:a4:fc:15:7a REACHABLE', Thursday, December 27, 2018 17:10:58 [DumaOS] Error parsing line in ARP table: 'fe80::1659:c0ff:fe4d:f3d9 dev br0 FAILED'., Thursday, December 27, 2018 17:10:58 [DumaOS] No wifi metadata f [did you look at the system log where it says ] I'm running new fw, modem is cm1000. i set up a staic ip on xbox. every thing worked fine but i put a new dishwasher in today and flipped the curcuit breaker off to wire it and flipped back on and its disconnecting from xbox. if you look at the system log it says DHCP lease change at the time it logs me out?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Remove the static IP address from the xbox and set it for automatic. Set a IP address reservation for the xbox ON the router.
How is the xbox connected? Wired or Wireless?
- Mark as New
- Bookmark
- Subscribe
- Permalink
wired, netduma jack looked at my system log last time and said type in the ip address on the xbox manually, then go to lang in the router and reserve that specific ip address,the xbox had a 8 at the end of the ip address was the only diffrence from my other devices. it worked great for almost 2 weeks that ive had the router untill i flipped my breaker turning the power off to the house and every thing in it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
and ive never had instant on on. lol
- Mark as New
- Bookmark
- Subscribe
- Permalink
i dont know if I set a static ip ? i went in xbox network copyed the ip address and mac address.... and then entered it manually so it wont change every time i turned on xbox , then went into lang in router and reserved that number and it fixed the problem. [ is that setting a static ip address?]
- Mark as New
- Bookmark
- Subscribe
- Permalink
soes anyone no what this means? every time it happens i get disconnected from xbox live ? [DumaOS] DHCP new event., Thursday, December 27, 2018 18:37:02 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Thursday, December 27, 2018 18:37:02 [DumaOS] DHCP lease change., Thursday, December 27, 2018 18:37:02 [DumaOS] DHCP new event., Thursday, December 27, 2018 18:37:02 [DumaOS] No wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
A static IP address is an address set ON the xbox or any other device. Not the router. A reserved IP address is an IP address that is set ON the router for a device. Using this, one needs to ensure that the device is set for Automatic IP addressing and remove any static IP addresses ON the device. Do not input a IP address on the xbox with a reserved IP address. This can cause problems and is not normal networking methodology.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok,so should i go into lan in router and delete the reserved ip address?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, remove the static IP address from the xbox if you set one there. Set the xbox to Automatic.
If you need to, remove the LAN side IP address setting from the router, reboot the router with the xbox ON and connected and let the router give a new IP address, if it does to the xbox. Then Reserve this IP address ON the router in the LAN setup by selecting ADD, look for the xbox listed, select it. Edit the Host Name, can be anything, just so long as isn't not blank. Add the reservation and select Apply. The router should reboot here. This is all you need.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ensure DHCP server is enabled on the router as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it hasnt happen again, but im sure you know what your talking about so ill try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, I I had known about the DHCP server sooner, hehe.
Ya, give the reservation a try and set the xbox for automatic. You'll be fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
did it work now?
