bretp2020's avatar
bretp2020
im having connecting issues please help
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Thursday, September 29, 2022 21:53:01
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Thursday, September 29, 2022 21:53:01
[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Thursday, September 29, 2022 21:53:01
[DumaOS] applying qos for zone lan, Thursday, September 29, 2022 21:52:44
[DumaOS] applying qos for zone wan, Thursday, September 29, 2022 21:52:43
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Thursday, September 29, 2022 21:52:37
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Thursday, September 29, 2022 21:52:37
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Thursday, September 29, 2022 21:52:37
[DumaOS] applying qos for zone lan, Thursday, September 29, 2022 21:52:36
[DumaOS] applying qos for zone wan, Thursday, September 29, 2022 21:52:35
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Thursday, September 29, 2022 21:52:33
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pendin, Thursday, September 29, 2022 21:52:33
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Thursday, September 29, 2022 21:52:33
[DumaOS] Geo-Filter cloudsync result 'true','Geo-Filter is up to date', Thursday, September 29, 2022 21:52:32
[DumaOS] Cloud sync: Router timezone is not UTC '-500', Thursday, September 29, 2022 21:52:32
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Thursday, September 29, 2022 21:52:32
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Thursday, September 29, 2022 21:52:32
  • Can you describe in a little more detail the problem exactly? The logs you've provided are just automatically printed during the start-up process, so they don't suggest any specific issue to us.
    • bretp2020's avatar
      bretp2020
      Im getting connectivity issues with a lot of dos attacks i think that is what is making my internet go off then right back online.
      [DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 09:48:39
      [DoS Attack: TCP/UDP Echo] from source: 94.102.61.29, port 34349, Friday, September 30, 2022 09:48:18
      [DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 09:47:43
      [DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 09:47:03
      [admin login] from source 192.168.1.2, Friday, September 30, 2022 09:46:51
      [admin login] from source 192.168.1.2, Friday, September 30, 2022 09:30:19
      [admin login] from source 192.168.1.2, Friday, September 30, 2022 09:29:41
      [DoS Attack: SYN/ACK Scan] from source: 51.38.105.47, port 7757, Friday, September 30, 2022 08:53:37
      [DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 08:52:23
      [DoS Attack: SYN/ACK Scan] from source: 46.174.50.8, port 443, Friday, September 30, 2022 08:51:51
      [DoS Attack: SYN/ACK Scan] from source: 222.92.255.14, port 5963, Friday, September 30, 2022 08:38:58
      [DoS Attack: SYN/ACK Scan] from source: 137.74.1.73, port 89, Friday, September 30, 2022 08:18:51
      • FURRYe38's avatar
        Do a whois lookup on those WAN IP addresses you see.
        Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
        What is the DHCP IP address range set for currently? Try 192.168.1.100 to .200
