kidcapri84
Dec 13, 2022Initiate
xr500 netgear QoS traffic prioritization
My traffic prioritization box is gone and it gives me a pop up box that says device not found when i open up the qos. what do i do to get it back or working?
- Netduma-FraserNetDuma PartnerDownload the DumaOS app on your phone, then go to the QoS page and delete the device on Traffic Prioritization. You should then be able to access the page on a PC without the error.
- kidcapri84Initiate
ty that worked
- JayLoveNet6AspirantWhat happens if you don’t see the QOS feature in the DumaOS app. I think it may be because the new update they added back in November. Please tell me what to do next in this situation.
- Netduma-FraserNetDuma PartnerIt's renamed on the app, so it'll be under Network Priority I believe or something similar
