× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How do i use my s8000 and x4s combined?
slicky
Tutor
Hi, I have a netgear x4s and s8000 switch and I was curious on how to setup the switch with optimal settings. I know the switch is supposed to be connected to the router, in terms of qos where would I set that up? I would connect all my ethernet devices to my s8000 and enable qos on there? or do i enable qos on the x4s and give my s8000 priority? I got the s8000 as a gift and thought I might as well use it. Also for the dynamic qos on my x4s, I run 940mbps down and 35mbps down. Can the x4s handle 600mbps or 500mbps as manual bandwidth setting on the download side of qos? I have many devices and I’m having a ton of lag. The advice is much appreciated.
Model: GS808E|Nighthawk S8000 Gaming & Streaming Advanced 8-Port Gigabit Ethernet Plus Switch, R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 1
Discussion stats
  • 0 replies
  • 975 views
  • 1 kudo
  • 1 in conversation
Announcements
Orbi WiFi 7
