× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Internet speed slows down when connecting to router
Pizorro
Tutor
I have in my house a NETGEAR RAX80, there is fiber internet using a KingType PN-B04C modem, the modem was install by the cable company.  We have 200 mg od download, when i connect the RAX80 router to the modem the speed comes down to 45-55 mg, even if connected with cable to the router it still shows 45-55 mg.  The cable company suggests not using the router, only the modem they installed, the problem is that I have all the house cabled with NETGEAR equipment and repeaters.
Again the router works perfectly, the issue is the speed, it comes down even with cable or wifi (same speed).  When using the modem installed by cable company it ready 180-195 mg, so I really do not know what to do.  They have come to my house at least 4 times and can not solve the issue, so they recomend not using our router only their modem.  I only have interet on one part of the house.
ANYONE can help with this issue PLEASE.
Enrique
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 8
Accepted Solutions
Guru
Re: Internet speed slows down when connecting to router
Message 6 of 8
All Replies
Guru
not much info on that modem. Does it have built in routing features?
Message 2 of 8
Pizorro
Tutor
Yes it does have router capabilities I believe, because it has wifi signal (weak) but it has.
Message 3 of 8
Guru
Try putting the RAX in access point mode.
Or putting the RAX's IP address into the modem/gateways DMZ.
Message 4 of 8
Pizorro
Tutor
I can not access the modem, cable company will not give access. Can you please explain how to put the router in access point?
Thanks in advnace
Message 5 of 8
Guru
Message 6 of 8
Pizorro
Tutor
Thank you, It works perfectly!  this solution was perfect!
Thank you again for your support!
Message 7 of 8
Guru
Glad it worked for you!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2079 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
