- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AXE1100 losing internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
hope someone can help.
I keep losing WiFi on my nighthawk axe1100
I have the most current FW loaded
rebooted the modem and nighthawk.
My internet is with Verizon Fios. I have there modem in bridge mode and changed the IP to be different from the Nighthawk.
A Verizon tech has changed the exterior equipment because that is what they believed to be the issue.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AXE1100 losing internet
what actual router do you have? Nothing you put is the model number.
What firmware are you on? not the "latest"
What ont from verizon is it connected to?
Does it only happen to wireless devices? Wired are fine
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nighthawk AXE1100 6E
the only device connect to the Verizon g1100 is the nighthawk router.
hardware Raxe500
firmwear is 1.0.8.70
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you leave the G1100 in router mode (disable its wifi) and put the RAXE in access point mode, does it function properly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I rebooted the Verizon modem about 2 hours ago so far iits still online this is the longest it has stayed on.🤞
- Mark as New
- Bookmark
- Subscribe
- Permalink
The rep put the version router in bridge mode.to be a pass through to my nighthawk
- Mark as New
- Bookmark
- Subscribe
- Permalink
WiFi on version router has been disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It wouldn't be the first "passthrough" mode that didn't function properly. Its one of the reasons I sometimes have people leave the ISP device in router mode (wifi disabled) and put the netgear in access point mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I put the ips router in WiFi mode and the nighthawk in access point
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have one wired device coming off the nighthawk and that too is losing connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
in regards to putting your primary gateway back in router mode, you'd have to check with your isp.
For the netgear in access point mode:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
just make sure the gateway is back in router mode before putting the netgear in AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For future reference, Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
