× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX 120 problem communicating with Samsung 5g phone
gfs10
Follower
I have a RAX120  running wpa2. the router communicates with all my devices, (even though i have found the range is really bad.) except one. if i connect my phone to the 5ghz. it connects but apps do no want to launch and the web browser comunication is hit and miss. if i connect to the 5ghz guest i have no problem and the speed is much better
i have turned off the wifi 6 capability as that was causing other problems
anyone have any ideas
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Newfiedrool
Virtuoso
Re: RAX 120 problem communicating with Samsung 5g phone
As you have 2 posts and seem to have an issue with both AX, WiFi range and devices I wire up a pc or Mac and download the latest update from the support page.
Do a manual update over the top, then reset using the rear pin hole method.
Set the router up as new, do not use a saved config profile.
Test.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 545 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
