- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 Multi-Gig Won't Connect to NAS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello. I'm trying to connect my Synology 1618+ to my RAX120 through the E10G18-T2 PCI-e card installed on the NAS to the Multi-Gig port on the RAX120. I am unable to get any kind of connection displayed on the NAS, says disconnected. If I unplug the same cable from the RAX120 and plug it into my SX10 switch 10Gbe port, it instantly works. Any help on how to correct the issue would be greatly appreciated. Thank you.
Have the RAX120 set up as aggreagation to the SX10. I'm trying to plug the 1618+ into the Multi-Gig on the RAX120. All firmware is up to date.
Contacted support, but was told I would receive a return call in 48 hours.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 Multi-Gig Won't Connect to NAS
@l0whit07 wrote:Hello. I'm trying to connect my Synology 1618+ to my RAX120 through the E10G18-T2 PCI-e card installed on the NAS to the Multi-Gig port on the RAX120.
Hi, There is no word on the Synology E10G18-T2 Specifications that this card is MultiGig capable for handling 2.5GBase-T (that's what the RAX120 port is) and 5GBase-T - only 10GBase-T is listed (interestingly not even the commonly workably 1000MBase-T.
Wrong card for this purpose I'm afraid - not a Netgear issue at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Guess I need a new card. Thank you very much for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's strange - Robbie does claim both come with the Aquantia AQtion AQC107 NIC, supporting 10/5/2.5/1Gbps and 100Mbps speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I face the problem excatly same as ~l0whit07~.....is there any way to connect Synology 1618+ to RAX120 through the E10G18-T2 PCI-e card on NAS to the Multi-Gig port on the RAX120 ?
if there is no way to make it happen, any suggestion for other PCI-e card to replace E10G18-T2 PCI-e card ?
Thanks
