× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
[RAXE500] Hard to scan 6GHz SSID because latest FW 1.0.7.68 doesn't send Unsolicited Probe responses
russellhu
Initiate
When my RAXE500 was running old FW 1.0.6.64 everything was fine and I could scan and connect to 6GHz SSID easily.  However after the router automatically upgraded to 1.0.7.68, I found I had to manually scan several times to find the 6GHz SSID, which is quite annoying.  Even worse, when the laptop wakes up from sleep mode, sometimes it has to take 3 minutes to connect back to the AP.
I've done some reasearch and managed to installed an air sniffer capable of scanning in 6GHz band, and found that the the latest FW 1.0.7.68 doesn't send "Unsolicited Probe responses" anymore, while FW 1.0.6.64 still did.
Could Netgear fix this and add "Unsolicited Probe responses" back to FW in the next FW release?
Thanks.
FW 1.0.6.64 - Unsolicited Probe responses :
FW 1.0.7.68 - Missing Unsolicited Probe responses:
Message 1 of 5
Altsai
NETGEAR Expert
Re: [RAXE500] Hard to scan 6GHz SSID because latest FW 1.0.7.68 doesn't send Unsolicited Probe respo
Yes, this issue should be pull-up to fix.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 2 of 5
DarrenM
Sr. NETGEAR Moderator
We have a new test firmware available you can find it at the link below.
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAXE500-Beta-FW-v1-0-9-72-is-avail...
Message 3 of 5
russellhu
Initiate
Thanks a lot for response, however seems the new test FW 1.0.9.72_2.0.36 still doesn't send the "Unsolicited Probe responses" :
Message 4 of 5
Altsai
NETGEAR Expert
what's your wifi 6E client? AX210? or?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1173 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
