× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Rax120
thehypnootoad
Luminary
Rax120
Hello again Im at the end of my tether with this rax 120 this is the second one now after getting rma.
It is doing the pretty much same thing as first one did. I switched back to my d7000 v1 and used wan from the modem and absolutely fine what is going on with this router.
1 used web ui and nighthawk to setup
Tried 3 different firmwares with reset after each one still the same result not connecting to devices properly even my s20plus5g which is ax won't connect. Does anyone have the answer or is it just me.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 3
thehypnootoad
Luminary
Re: Rax120
The only solution I can find is going into lan and reserving each address via a static ip the dchp connects devices but its over hours and not all devices connect and some just refuse.
Message 2 of 3
Re: Rax120
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 735 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
