- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SmartConnect causing TV issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
I got my RAX120 about 3 weeks ago and it was very stable at first. Then I activated "Smart Connect". My house has 2 of the new AT&Ttv boxes (basically android TV streamers) and they were constantly dropping their connections while I was watching. I turned off smart connect and they're back to being stable. They require an always-on connection for the TV guides and such so I dont think they react well to being channel bounced. I'd have to go into their settings and manually reconnect to the network.
And frankly they shouldn't be channel bounced. SInce they never move why would the router keep trying to optimize their connection? There should be a QoS rule or something where a device gets its connection locked as it doesnt change, where an iphone or ipad may need its connection adjusted as it roams around the house.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SmartConnect causing TV issues
Hi scoobycarolannc,
If you recently purchased the device, I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may start by registering your device using the link below.
https://www.netgear.com/support/default.aspx
Christian
User | Count |
7 | |
4 | |
2 | |
2 | |
1 |
