× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Super slow wireless speeds - AX120....
kermitWyo
My streaming has been off lately and I finally ran a few speedtests both hardwired to my ISP router and to my Nighthawk AX12... hardwired is @ 450MB down/25 up... wireless is @75MB down/20 up...
This router has me a bit stumped (or it is over my head). I didn't have any issues with my Netgear AC1900 - but it wouldn't work with my new modem required for the high speed connection.
I realize without any settings information it is damn hard to troubleshoot anything... just hoping for some obvious areas to check in the settings to see if something got changed that I wasn't aware of (it used to work great).
Thanks...
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 9
Christian_R
NETGEAR Employee Retired
Re: Super slow wireless speeds - AX120....
Hello kermitWyo - Would you mind providing us with the firmware version your router is currently on?
~Christian
Message 2 of 9
kermitWyo
Hi Christian,
Sorry - I forgot to include that...
v1.0.0.84
I thought I was going to get it updated until the x.86 upgrade was pulled. I dont know if my router did something as a pre-update routine that stalled when the new firmware was pulled or what happend. I was getting a full 400MB - 445MB connection wirelessly...now I cant even break 100MB.
thanks
Message 3 of 9
Christian_R
Hi kermitWyo,
Thanks for confirming. Could you provide more details on the device you're using to test your wireless speeds and if you've used other devices to run a speed test? Also have you tried disabling QoS to see if that helps?
~Christian
Message 4 of 9
kermitWyo
Hi Christian,
I ran two different tests ...
1). a hardwired test from my AppleTV using the SpeedTest.net app. I got over 400M connection results to three different servers in my region.
2). A wireless test through the Nighthawk using an Apple Airbook connected to my wireless 5G network. I got a 75-80M connection.
I verified that test with an iPad running Dslreports on Safari browser.
I think QoS is turned off on the router.
Thanks
Alan
Message 5 of 9
Christian_R
kermitWyo - Have you gotten a chance to change the wireless channels for both 2.4/5GHz? You may also try performing a factory reset on the router to see if the issue persists. We have received some feedback that performing a factory reset has resolved WiFi speed issues.
~Christian
Message 6 of 9
kermitWyo
I have not tried that yet. I will do so tonight and report back.
thanks
Alan
Message 7 of 9
kermitWyo
Hi Christian,
I changed channels on both frequencies and it did no good. I have noticed the 5ghz frequency is no longer broadcasting like it used to... there is no longer a way to select it from the WiFi setting on my devices... only the 2.4ghz frequency is available.
I haven’t tried defaulting it to factory settings - but mainly because I’ve been buried at work and haven’t had the energy to reset it yet. Maybe later today.
Thanks
Message 8 of 9
Christian_R
Hello kermitWyo,
Thanks for getting back. Were you able to factory reset the router over the weekend?
~Christian
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3955 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
