- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LAN Invalid MAC address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When going to add a static ip under Advanced > Setup > LAN Setup. Going to add an address reservation don't work for any of my devices. When clicking add I get the message:
Invalid MAC address. 80E6500BC742 |
for MAC address 80:E6:50:0B:C7:42, ip 192.168.1.32.
Hardware Version | R8000P |
Firmware Version | V1.4.4.94_1.3.56 |
GUI Language Version | V1.4.3.86_2.1.46.1 |
LAN Port | |
MAC Address | 3C:37:86:F2:C2:5E |
IP Address | 192.168.1.1 |
DHCP | On |
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is a known issue and has been passed on to NG.
Find downloads here;
https://www.netgear.com/support/product/R8000P.aspx#download
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LAN Invalid MAC address.
Note: this was previously working before router software update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After the update, did you try a factory reset?
If that doesn't help, you can always downgrade back to the older version of firmware.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
you could downgrade the FW, add your reservations, then upgrade again and the settings will stay tho it’s a hassle! 😇
that’s what I’ve been doing with the latest FW and the NTP // Invalid Mac problems! 🙂
the 6to4 was solved with using DHCP server option! 😀
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would use the word "solution" carefully. LOL It did not work for me., I am at the latest firmware and this feature worked then but the upgrade, not only broke the feature, but deleted all of my existing address reservations #doublefail
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend using last working version of FW.
This is a known issue and NG IS working on a solution.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
