GypsyBluebell
Oct 28, 2020Aspirant
Password reset for Nighthawk AC1900 WiFi Range Extender
I don't have the paperwork that came with my WiFi Range Extender (I think hubby threw it out with the box) so I don't know the password. How can I find out the password or reset the password?
- And you still didn't specify if you're wanting the wifi password or gui password.
Default login info:
login: admin
password: password
You can find manuals, firmware, and install guides here:
https://www.netgear.com/support/product/ex7000
to reset, push and hold reset for 7-15 seconds while its powered on.
that'll get you back to the defaults.
- GypsyBluebellAspirantThank you however I am still unable to reset the password for my WiFi Extender.
Which password?
The wifi password or the login to the gui?
Did you push and hold reset for 7-15 seconds while it was powered on? the lights should change.
What are the led's on it doing?
