nigelburnett
May 05, 2017Aspirant
Port forwarding not working
Port forwarding table set up identically to Linksys router. Cannot open any port. I have 5 webcams with static Ips each using a unique port. Latest firmware: V1.1.0.32_1.0.1. Cams all work fine with lan IP address. TIA.
Sorry, I thought I had closed this thread. The problem was that my cameras were still configured the the other router's gateway address. Once I changed the cameras' settings, everything worked. Many thanks to Netgear tech support who spent an hour on the phone to find my problem.
Be sure that uPnP is disabled on the router if your using PF configurations.
Besure your ISP Modem doesn't have a built in router. Bridge it if it does.
- nigelburnettAspirant
uPnmP off for sure. vanilla docsos 3 modem with no router
Should work ok if you have the PF configured correctly.
