Orbi WiFi 7 RBE973
Reply
R6700v3 OpenVPN not working
Holmis
Guide
Can not get OpenVPN to work... I have followed the instructions below.
see attached log file... something about "TLS error: Unsupported protocol."??
log
Regards
Holmis
Message 1 of 16
Kitsap
Master
Re: R6700v3 OpenVPN not working
For test purposes, suggest you try the configuration as shown in the attached screen snip.  After you make the changes, you will have to generate your client configuration files again and transfer them to the client.
Make sure you are testing your connection from a client device that is not connected to the same network where your router is running the OpenVPN server.
What type of device are you running the client application on?  Android, Windows, ??
Message 2 of 16
abdsea
Guide
The issue is due to server TLS level is 1.0 and it is considered insecure. OpenVPN client calls it insecure mode.
Go to settings -> advanced settings ->  choose "Insecure" and then retry connection. We will not be able to do much without netgear providing a firmware update to switch OpenVPN server settings to use TLS 1.3 or above.
Changing UI settings will not solve the problem as suggested by prior post.
Message 3 of 16
Holmis
Guide
Thank for the answer, but is it in the OpenVPN client I need to change or in the router?
I cant find any "Insecure" setting in my client or do you recommend a version of the client?
I use OpenVPN GUI or is there another better OpenVPN client?
regards
Stefan Holmgren
Message 4 of 16
Holmis
Guide
Ok... downloaded "OpenVPN Connect" and found the advanced setting...
but now I cant import the profile?!?...
Message 5 of 16
Kitsap
Master
Repeat question: What type of device are you running the client application on? Android, Windows, ??
I cannot see an inserted image until a moderator approves it.  If you attach an image, I can see it as soon as it is posted.
Message 6 of 16
abdsea
Guide
can you post your profile trying to import? please blank out your domain name or other private information. The option file contains error without looking if i have to guess
proto option has some invalid characters or some information. Proto can only be TCP or UDP please check that. For most VPN configuration you need to have this set to UDP so can tolerate some errors.
Message 7 of 16
Holmis
Guide
Hi... the profile looks like this.. (client1.ovpn)
client
dev tap
proto udp
dev-node NETGEAR-VPN
remote xxx.xxx.xxx.xxx 12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
regards
Stefan
Message 8 of 16
abdsea
Guide
hi Stefan,
your profile looks good, apologies for missing it earlier. TAP mode is not supported on OpenVPN 3, i missed the TAP message from your screenshot. Try using the 2.x client from the download page https://openvpn.net/client/client-connect-vpn-for-windows/
thanks
Message 9 of 16
abdsea
Guide
or the community download https://openvpn.net/community-downloads/
Message 10 of 16
Holmis
Guide
Thanks a lot for helping me, but with this version I'm back where I started, my first post...
hmm... maybe you can find something in the log file, attached it as a pdf... (I removed domain name)
Message 11 of 16
abdsea
Guide
did you change the insecure mode, if the option available?
second, you could try adding this in a new line "tlsversion-min 1.0" in your profile based on this error message
"If your OpenVPN client is between v2.3.6 and v2.3.2 try adding tlsversion-min 1.0 to the client configuration to use TLS 1.0+ instead of TLS 1.0 only "
Message 12 of 16
Holmis
Guide
yes added "tls-version-min 1.0" to my profile, but still same error...
maybe I need an older version of OpenVPN GUI??... installed OpenVPN-2.6.6-I001-amd64
Regards
Holmis
Message 13 of 16
Holmis
Guide
Now its working... downloaded an older version of OpenVPN... openvpn-install-2.4.6-I602
Regards
Holmis
Message 14 of 16
abdsea
Guide
Glad you found the right client version, it should be simpler but an arduous effort 😂🤣
Message 15 of 16
cg49me
Initiate
Different router, but same problem (Orbi Wifi 6 RBR850).
Firmware version is V7.2.6.31_5.0.24.  I'm assuming that last bit has something to do with the release date (May 0th, 2024?).
Latest OpenVPN client download v2.6.11 is dated June 20, 2024.  Client wasn't connecting, same as OP described.  Uninstalled, and downloaded v2.6.10 dated March 20, 2024 - now it's working!
For anyone else having similar issues, try downloading the latest OpenVPN client version dated prior to your router firmware...?
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 7119 views
  • 6 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
