Mariocarr's avatar
Feb 26, 2022
R700
Il router si resetta e non ci si collega con la wifi
  • FURRYe38's avatar
    In inglese per favore
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • Mariocarr's avatar
      Mariocarr
      Tutor
      The actual firmware is 11.023
      I use channels 5 and 2,4 in auto mode
      I have not other connection near to me.
      I traied to reset the appliance but now only the first led is on and all the other are off.
      • FURRYe38's avatar
