Anonymous's avatar
Anonymous
Aug 07, 2016
R8000 Wireless is off
I have a R8000 wifi router with firmware V1.0.3.4_1.1.2 and the wireless is off from the web UI and the genie app. However the LED on the router are on. I am unable to access wi-fi eventho the wifi settings are ON and brodcasting the ssid. I have try rebooting, factory reset and went back to an older version of the firmware on the router. Still the Wifi is Off. Any idea on how to fix this?
  • Anonymous's avatar
    Anonymous
    Aug 08, 2016
    Verify you're using correct AC adapter.
    Anonymous
    Press reset until power led flashes ...use defaults after reboot....if same problem contact support
      Anonymous
      I actually did this however the problem still persist. I am out of support contract as it was purchased in 2014. Not sure what went wrong with the router.
      • TheEther's avatar
        TheEther
        Guru
        Did you inadvertently push the Wi-Fi button?  It toggles the Wi-Fi radios off and on.
