- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2,4 Ghz for Guest network
- Mark as New
- Bookmark
- Subscribe
- Permalink
How can i enable my WIFI Guest Network only for 2,4Ghz and not 5 Ghz?
I have a mesh system MR60 Nighthawk with 2 satelites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2,4 Ghz for Guest network
Might not be possible with a Mesh system. They don't always allow you to split bands.
You may get better advice in the right section for your equipment and not here, where the topic is Nighthawk WiFi Routers.
That's probably here:
Nighthawk Mesh System - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is not for the GUEST Network but, it is now possible to split the regular network on the Mesh system (at least with firmware v1.1.6.124). You will need to go to ADVANCE Tab > Advace Setup > Customize Wifi Network, In there you sill find the option to Customize 2,4Ghz and 5Ghz by separate.
