Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Getting a wired gig connection on the router seems impossible
mjmohsen
Hey all,
I have a Nighthawk Mesh WIFI 6 router with 2 satellites, and so far it has worked wonderfully well.
Today I was finally able to update my fiber connection to 1 gig from my ISP, and I'm not getting teh expected performance on the router.
I get around 550Mbps at the router port. (acording to teh speedtest on the QoS page. (QoS turned on or off makes no difference)
When i bypass the router and connect my cable from my ISP directly to my computer, i got up to 1.3 Gbps.
Any ideas on what the issue could be?
Message 1 of 9
Accepted Solutions
mjmohsen
Re: Getting a wired gig connection on the router seems impossible
Here's how I solved my speed issue:
I have an older R8300 router, that i set to factory settings, and while it also doesn't recognize the speed is full gig, it strill transmits that to my wired computers
I now use the Mesh 6 system as an access point for the other router.
Message 9 of 9
All Replies
knightz01
Apprentice
@mjmohsen
No help from the data sheet that I can find as it only states 'Experience the next generation of WiFi 6, perfect for medium to large homes up to 4,500sq.ft.† and internet speeds over 100Mbps, I'm on 500Mbt & expecting an upgrade soon so would be interested in knowing the limitations
knightz01 (Kev)
Message 2 of 9
Guru
which actual system do you have? There's several wifi 6 mesh versions.
What fibre gateway was installed?
you can try factory resetting the primary router and then reinstall it. During the install, leave access control, traffic monitoring, qos, and parental controls all disabled. Try testing the speed after the install and minimum changes to the settings.
Message 3 of 9
mjmohsen
The NightHawk one, Models are MR60, and 2 MS60s (router and 2 satellites)
The gateway is irrelevant as the signal coming in has the correct speed, and the issue only happens on the router itself. If you must know, the fiber signal comes from Ziply Fiber.
I'll try refreshing the router to factory settings,
Message 4 of 9
Guru
Gateway isn't "irrelevant".
If its a gateway with its own integrated router, it could be using its own form of qos to limit speeds.
Its why we ask.
Message 5 of 9
mjmohsen
Fair enough, however there is no gateway, there is only the signal that comes straight from teh fiber to the modem outside the house.
The ISP confirmed there is a gig connect at the ONT, which is passed on to my ethernet cable inside the house.
Just in case I had not mentioned it clearly, if I bypass the router entirely, then I get full signal (i.e. when i wire the cable directly to a computer)
Thanks for taking the time to asnwer @plemans
Message 6 of 9
Guru
Again, some ont's have an integrated router.
Easy check? put the router in Access point mode. If it works and all devices work, the ont has an integrated router.
if you can't connect, then factory reset the router and start over.
Message 7 of 9
mjmohsen
Cool, I'll try that real quick.
Message 8 of 9
mjmohsen
Message 9 of 9
Discussion stats
  • 8 replies
  • 3596 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
