× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MK62 How do I make 2.4 and 5ghz separate?
Duddydud
Follower
Hello,
Just set up my MK62 mesh system, and I can't locate the 'customize wifi setting' all the directions speak of to separate the 2.4 from the 5 channel.
Anyone know if this is possible?
Message 1 of 2
Guru
Re: MK62 How do I make 2.4 and 5ghz separate?
the 80 series had that option originally and I'm pretty sure it was rolled out to the 60 series you have in firmware updates. (so make sure your firmware is current if you're wanting to do this)
The KB article doesn't show the 60 series but it should work if you follow this guide.
Can I create separate 2.4GHz and 5GHz SSIDs on my Nighthawk Tri-band Mesh WiFi 6 products? | Answer ...
Message 2 of 2
Discussion stats
  • 1 reply
  • 955 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
