Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Mesh router for 1gb fibernet connection
aha71
Follower
Hi
I have 1Gb fibernet connection with an effective speed of 800Mb down and 900Mb up (tested). I get around 400Mb  with my current Nighthawk or Nokia SurerWifi tested on Apple Macbook Pro M2 Pro or Iphone 14.
Which mesh router would you recommend when I want to take full advantage of a 1 Gbps fiber optic connection?
regards
Anders
Message 1 of 3
Guru
Re: Mesh router for 1gb fibernet connection
What model MESH router do you have? MK?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 2 of 3
Tested how? Wifi?
What are you doing that needs a connection at 1 Gbps?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 384 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
