- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New MS60 won't pair, just blinks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Subject pretty much says it all... New out of the box MS60 just blinks white when plugged in. Does not respond to the reset button (quick press, 10 second press, 1 minute press)... It just blinks. MR60 does not find it Sync button does nothing either... It just blinks. Is this a bad satellite, or what should I try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New MS60 won't pair, just blinks
Hello JohnBinTN,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
