- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AX3000 can't connect after power goes out and comes back
- Mark as New
- Bookmark
- Subscribe
- Permalink
Every time the power goes out and comes back I'm experiencing the same issue, none of my devices can connect and I need to power off and on the router. This is very annoying especially because I have cameras that appear offline every moment there is a power outage.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Never mind, found the solution.
I disconnected the device and threw it in the trash, garbage service should take care of the rest 😂. Google smart mesh is working flawlessly, did a couple of test and everithing just works without any mess. Thank you very much for your time!
Also whenever I turned on qos the device started diconnecting devices, when I tried to access a connected device from the list by clicking on it the device screen displayed other random device, not the one selected on the list. Just a note for future references.
Thank you again, have a great day.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AX3000 can't connect after power goes out and comes back
What modem/gateway is the router connected to? Some are more critical of the reboot timing.
If thats the case, a cheap UPS might be a good idea for the modem/router
- Mark as New
- Bookmark
- Subscribe
- Permalink
To add to this, I saw exactly this phenomenon when I had a D6400 DSL modem/router on bridge mode. The modem took too so long to connect that the R7800 router behind it timed out while the modem was connecting.
In your case, you are talking about an AX3000. Which one?
AX3000 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router is a MR60 with 2 satellites connected to a Nokia beacon 1 with wifi disabled. The MR60 is connected to a Battery backup.
Just now the power went out for like 3 seconds and none of the devices was able to connect again, even when the router has its dedicated battery.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The nokia is its own router And disabling its wifi doesn't disable its routing capability. It leaves you in a double nat.
Do you have the MR60 in access point mode? Or the MR60's ip address entered into the nokia's DMZ?
Not sure why you're running the nokia beacon 1 as its just a router from what I could tell. It doesn't have an ONT/modem/etc.
Is it something required from your ISP? And what does it connect to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Default setup, only thing is that I disabled the modem’s wifi since tats the mesh purpose, provide wifi to an extended area that the modem can’t reach.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Retired_Member wrote:
Then Nokia its a modem it connects to the ISP antena...
Does it have a model number?
Is it a device that connects to the mobile/cell network?
Those "modem/hotspots" come in various forms, with and without any router features.
Netgear makes various models. The conversations in the section where they discuss these show that they are not the easiest things to set up with a router. Cable, DSL and ONT devices are much simpler.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
