- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk MR60 No internet connection when doing a 100mb/s between two computers
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a gibibyte network switch plug into the router. when I transfer files between one and another the entire wifi network will not be able to connect to the internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk MR60 No internet connection when doing a 100mb/s between two computers
I don't follow that. What is this network switch?
What are you transferring files between?
Your subject says two PCs.
Where does WiFi come into any of this?
Just another user with time on their hands.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have two pc connected to the ethernet which are connect to the router. when I try moving files between them all other devices connect to the internet will stop working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both PCs are wired to the router?
There is a switch in there?
What is the layout?
MR60 > Switch > PCs
Then the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
